Disables the MPLS RSVP-TE fast reroute (FRR) protection feature.
Enabled.
When FRR is disabled on the LSR, all established FRR LSPs on the local LSR are torn down, and only standard LSPs can be signaled and processed. The configuration for any existing FRR LSPs is retained, but it is not used until the FRR protection feature is enabled. This command can be used to test the performance of an LSR without the FRR functionality or when the LSR doesn't behave as expected for either standard or FRR LSPs.
The following command disables FRR protection on the local switch:
disable mpls rsvp-te fast-reroute
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
